ABS-Fault
Gregg1100
x 5
ABS-Fault
Unread post by Gregg1100 »
When one does the resistance testing on the ABS unit, I take it that the wiring plug is tested. The top that fits onto the abs body.
Greg
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
x 8058
Hi Greg,
Yes, correct. You don't want to go trying to measure resistances in the ABS unit itself!
The beauty of testing right at the ABS ECU plug is you test all the wiring to the sensors.
Disconnect the battery before disconnecting the plug..
Gregg1100
x 5
ABS-Fault
Hi Jim,
Thanks for your quick reply. Will be looking at that this weekend.
Did a bounce test on car yesterday---2 front spheres are solid, and n/s/r is dead. Wondered why it was like a pogo stick. Ordered 4 from GSF. The accy one pumps me up when I sit on rear of car, and infrequent ticking so will put that one on back burner, till I see what the other balls do.
Greg
MikeT
x 232
Unread post by MikeT »
Greg, you may want to try cleaning the LHM filters and see if the time between ticks improves. I changed my accu sphere and it didn't improve as much as I hoped but cleaning the filters made all the difference.
Gregg1100
x 5
ABS-Fault
I checked the resistances on abs plug, and found O/S/F to have no reading--all the other were up around the 1080( as described in this forum ). Fitted a new sensor lead, ---still got light on. Multimeter now dead, so have to get another before I can check it out again.
Anyone got any ideas as to why new lead didn't knock the light out?.
Thats what I liked about my old L reg TD Xant---it didn't have abs---didn't need it--nor do I- unecessary complications.
Thanks,
Greg
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Have you checked the sensor itself, i.e. at the connecting socket.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Gregg1100
x 5
ABS Fault
It was a new sensor with lead. The plug contacts were as clean as a whistle. Stupid bloody place to put plug though. Of course, just cos it is a new lead, doesn't make it 100% .. Will buy a new multitester from Aldi tomorrow. :?
Greg
reblack68
Unread post by reblack68 »
I was going to suggest buying a new meter from Lidl or Aldi (couldn't remember which). Anybody who doesn't have a meter should pop in and buy one, it's too useful not to buy for under £7.
Does your Xantia have the later type of ABS? The later ones won't acknowledge a repair until you hit 20mph.
Richard
Care of a 1994 205 D.
Gregg1100
x 5
ABS-Fault
Thanks all for your input. When I fitted the new sensor, I never tried the car. It was when Richard ( Reblack ) mentioned early types and late types, and would reset on later types after 20MPH, that I tried it, Light went out at 16 mph. YIPPEE.. One less mot thing to worry about. :D :) :lol:
Regards,
Greg
