Evening all,
Friend of mine has just rang. He has a 2002 Xsara Picasso with 1.9 engine. It will start and fire, run for about 10 seconds and then cut out. In the time it starts it will rev but then dies. He says he is low on fuel so I've told him to put a gallon of diesel in and ring me back. Suspecting diesel filter if the fuel doesnt solve it.
Any other ideas ?
Stu
Xsara Picasso Running Problems
AndersDK
Hi Stu -
It is very important to avoid a low fuel situation on a diesel.
Otherwise you are into priming business and perhaps some longish engine cranking - for a reluctant lumpy start.
Other issues could very well be leaking fuel lines, as air intake by the fuel lines is a sure hard-starter and lumpy runner on a diesel.
Also check for any possible water contamination of the fuel.
It aint gonna run on water mate
Anders (DK) - '90 BX16Image
stuartadair
Thanks. He's put a gallon of diesel in and now it wont even start at all. Apparently it wasnt that low in the first place so it wasnt running out of fuel.
The car is in Northampton and I'm in Tewkesbury so its a bit difficult to diagnose but I'm thinking a blocked fuel filter as the next logical step ...
- x 1439
It won't be a 1.9 if it's a Picasso - it will be a 2.0 HDi. Depending on which system is fitted, the 'usual' failure is the low pressure lift pump in the tank (only fitted to Bosch injection systems). TBH it's unlikely to be a blocked filter (unless he's been doing something really stupid like running it on old chip fat....). Maybe get the rear seats up / out and the carpet up and look for the (big) tank grommet, lift this, and then give the tank housing a clout whilst the ignition is on to see if it springs into life. After that, it is garage with diagnostic equipment I'm afraid - there are loads of sensors on these engines, and lots of checks by the ECU before it will allow the engine to start - the only hope of getting it fixed is with a computer
Best to take it to a Diesel specialist though.
pikecrazy
Re: Xsara Picasso Running Problems
Oh dear could be the High Pressure fuel pump , this happened to minestuartadair wrote:Evening all,
Any other ideas ?
Stu
2013 Berlingo Multispace 1.6 XTR 115bhp
2003 2:0 HDI Dispatch Van 186000 miles......gone
2000 Xantia Hdi 90bhp Forte Estate 97000 miles gone..........to heaven
New High pressure Fuel Pump and Patched ECU , Blower Module fixed by CitroJim
- x 1044
I agree it sounds like a LP fuel pump in the tank, unfortunitely you cant access it from under the seats its a drop the tank down job.
Get underneath it whack the lowest point nearest the filler neck with a rubber mallet whilst cranking it & it should kick into life. will need replace though with the seal.
