Today while adjusting my handbrake, I discovered my nearside rear wheel is binding (even with the handbrake cable slackened a lot), the other side rolls fine, and stops as it should. It takes a quite a bit of effort to move the wheel, it's just about turnable with the wheel off holding two wheel bolts.
Question 1 is, what size is that big nut? Is is a 33 or a 32mm?
What happens if I open that nut, will the cover come off and I can see what's binding the brakes? What is usually the most likely culprit?
Again haynes manual is a bit sketchy, I am not the most clued up on drum brakes.
This nut (see below) looks dodgy, whats happened there, dad reckons it will come off. I can't imagine how it's assemebled, looks like some 'master mechanic' has locked the nut onto the thread/cap (whatever it is) because he didn't have a circlip??
Any ideas and walktroughs for me there??
