This fault is on a Megane Scenic where the car cannot now select reverse!
I have previously driven this car, and it was O.K.
Looking under the bonnet I can see that the selector mechanism at the gearbox end is under the car.
I checked under the gaiter, and can see that there is a wire which is operated by the mechanism, that you operate to select reverse gear. I.E the collar that you pull on when you select reverse.
So is there a common problem with this, and a known fix to sort it out ?
The car is on 02 plate with the 1.9 litre diesel engine, and has a manual gearbox.
Megane Scenic Gear Selection Problem!
ACTIVE8
- x 6
ACTIVA
ACTIVE8
- x 6
