306 HDi head gasket replacement
simonaoz
Is it possible to change the head gasket without removing engine on a 2001 306 HDi ( no turbo )
- x 8067
Hi Simon,
Welcome to the forum
Although I've not had the pleasure, I'd be very surprised if the head won't come off in-situ. Most engines will, the exception being the 2.1TD but I know for a fact the 1.9TD head will come off OK.
It all depends if you can effectively get the manifolds off. Whatever, it'll be a squeeze and like a lot of jobs on a PSA vehicle, it will be just doable for a contortionist with 10" fingers
You may well be better advised to pull the engine right out. It could be quicker and easier in the long-run. I've been there several times and one day I'll take my own advice
What is the problem with the engine?
simonaoz
Hi Jim,
Thanks for the reply. It looks as if the head gasket has gone as the water system is over pressurising. Water is being forced out of the radiator cap. My local garage who normaly service the car say that the engine would have to come out and that I'm looking at a £1000 bill at least, maybe more, if for instance the head is cracked.
Simon.
Simon.
- x 8067
Hi Simon,
This post may help. I appreciate it's for a 206 but the basic principles will apply..
http://www.frenchcarforum.co.uk/forum/v ... ead+gasket
simonaoz
