DIM DIP RELAY LOCATION
xantia93eko
Unread post by xantia93eko »
Hi i have read a lot of posts that mention dim dip system on early xantias.I am sure i have a problem with this on my 1993 xantia .The lights always seem to be on half power and then very very rarely they will operate at normal brightness (still not brilliant)and then once the lights are turned off and back on again they go back to dim.I have been told this could be the dim dip relay but cannot find anyone that knows where the relay is located
thanks in advance Dave
THELABMAN
Unread post by THELABMAN »
I don't think Xantia's have a dim dip headlight system, I'm on my third and none of them has been equiped with it, the first was a 1995 1.9TD SX, the last two are the the one's I have just now.
Citroen C5 2.0 HDI SX Hatchback - 2002 (52)
Xantia Sensation 1.9TD (T) Mallard Green (Gone to the breakers)
x 8263
I've never come across dim dip on a Xantia although that is not to say it is not possible. My 1993 TD does not have dim dip but my father's 1994 Pug 205 has.
The best way to find out is to look for a long aluminium cylinder with three wires exiting it and ending in a normal Citroen-type plug. This is the dim-dip resistor and as it runs warm in use, it'll be somewhere exposed to cooling air in the vicinity of the rad and herein lies its downfall; it gets corroded and the connections fail at the plug. I have one here from a 205 where the plug just felll apart as soon as I touched it in an attempt to clean it.
Best thing, if you do have one, is to do away with it.
Homer
x 16
Unread post by Homer »
Dim-dip only had a short life, it was a legal requirement in the UK from April 1987 to some time in 1988.
It was fitted to some BXs, but the K reg I had didn't have it so I doubt it was fitted to the Xantia.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Judging by the amount of complaints about the performance of Xantia headlights I don't think a dim dip relay would be necessary :lol: or maybe Citroen never worked out how to turn it off :lol:
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
wrinklet1
Unread post by wrinklet1 »
Hi, Xantia's dont have dim dip fitted, the sidelight bulb positioning makes it un-neccesary. Well really it has dim everything on the lighting dept.
I did a little rewire on my mk1 xantia, put a couple of relays in, and wired the lights directly from the battery through individual fuses of course. This did make a difference. I did eventually put in 100watt bulbes from halfrauds on the dip side.
Didnt blind anyone or burn any wiring out.
Now I am running my mkII xantia with HID lighting, megga lighting, but had the allignment checked by mot centre and had it dipped a little lower.
Paul
1xAmi,3xGS,2xBx,2xAX,2xSaxo,1xXantia mk I,2xXantia MkII,1xC1,2xC2,
