Front brake piston stuck
awg2
Unread post by awg2 »
Whilst replacing the front pads the phone rang and I went to answer it. On returning to the car I could see that the brake piston had moved out so far that I could not reseat the caliper as the gap was now thinner than the brake disc. There are also a few drops of LHM on the ground which have dripped from the boot. I am unabl either to retract the piston or to rotate it. I have made a later attempt to retract the piston but to no avail.
The car is now conveniently placed diagonally across a double garage as I am unable to replace the wheel.
Does any one have any suggestions before I flail the car with a small sapling?
C5 2l 2001 130K - daily use X-country (must change job)
Xantia 1.9TD Estate VSX 1995 111k - daily use X-county
3xBX 1xGS 1x16 TS - oh that was a Renault
x 1240
Unread post by Peter.N. »
It must be possible to move the piston somehow. The problem probably is that it has not gone back in square. If you can remove the rubber boot, look at the sides of the piston, you will probably find that it is tilted slightly, find the high spot and tap it with a soft hammer and it should go back in, then you will be able to turn it.
awg2
Thanks, I shall it with an ammer when I get home.
Wish I was in Dorset.
awg2
I have now managed to rotate the piston but it does not wish to retract. How long is the piston? It appears to be only just in the barrel but will not remain true when I turn it.
x 1240
I have never had one to pieces, so cant say really, but they do have a very fine thread, if you can hold it square and rotate it should go back but it will need a lot of rotation.
awg2
Now sorted following a rescheduled hospital visit.
In the end it just, sort of......screwed in.
x 1240
Well done! Just a question of perseverence mostly. :)
