Radiator - all the same?
RugbyPete
Unread post by RugbyPete »
Will a xantia petrol radiator fit a 1.9td?
deian
Unread post by deian »
Personally I would say yes, if the physical dimension are correct. In saying that... remember that a petrol engine will generate more heat compared to a diesel engine, so the radiator might be bigger (in size and cooling output), so if the cooling output is more, then the diesel engine might never warm up sufficiently to run at optimum efficiency. Although in this case the thermostat would be the judge of that.
So thats a yes from me, after all the scientific hoo ha contradictory pro's and con's.
RugbyPete
ook, so what about the fixtures, will it physically snap in to place? Or would i need to use cable ties
P.s
Thanks for the lightening response
citroen7
Unread post by citroen7 »
well if they are the same why are diesel rads more expensive?also there are different fittings during the change over from mk1 to mk2
x 8281
citroen7 wrote:well if they are the same why are diesel rads more expensive?also there are different fittings during the change over from mk1 to mk2
Generally a diesel rad has more cooling capacity, hence the greater cost.
Early rads have spigot hose connectors (i.e. hoses held on by conventional clips) whereas from about '97 on the bayonet hose connectors were introduced. You could use an earlier rad on a later car and vice versa by swapping top and bottom hoses.
I'm not sure about compatibility of rads between models but I would have thought the 1.9TD rad would fit most. It has mountings at the rear for the intercooler but on a petrol one this would not be an issue.
The only sure compatible items I know are that the 2.1TD and Activa share the same rad, amongst many other items.
It was always thought of as a good cheap cooling upgrade to use a diesel rad on a similar petrol car. A popular thing to do on a Pug 205.
THELABMAN
Unread post by THELABMAN »
I'm not sure about petrol/diesel compatability but the place I got the radiator fitted into my 1.9TD sensation last year said that there are three different rads for the 1.9TD coming in slightly different witdh and height and with or without aircon.
Citroen C5 2.0 HDI SX Hatchback - 2002 (52)
Xantia Sensation 1.9TD (T) Mallard Green (Gone to the breakers)
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Xantia rads vary quite a lot, my V6 has both hoses alongside each other, the Activa uses spring clips, the TD has conventional clips, a 1.8 16v has an attached header tank and that's just to start with :?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1240
Unread post by Peter.N. »
Although the diesel is more thermally efficient than the petrol driven sensibly, if a diesel is thrashed it starts to run very inefficiently and produces more heat than a petrol engine. Hence the precautionary need for a larger radiator.
