Anyone know what speed rating the tyres on my xantia estate should be? Mitchilins website states that the std homologated tyre is T rated (118 mph) ts website reckons they should be H rated (130mph) the ones currently fitted are H
I'm looking at putting 4 mitchelin energy tyres on and the price difference between the speed ratings is £13 per tyre !
tyre speed rating
XantiaMan
- x 18
Depends what engine it is, i have some V rated and H on my car but it would never do 130mph, runs out of revs before then. I'm sure it says on a sticker on the drivers side pillar what the original tyres spec/pressure should be.
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
2017 Fiesta ST
tdolman
Stempy
I think the speed rating has to be the one immediately higher than the top speed of the car, so if your car has a top speed of 118mph then you would need tyres rated at 130mph but if the top speed is 110mph then the 118mph rating is fine. The handbook usually states the tyre rating and also the top speed of your model.
Lexia ponce
Lexia ponce
MikeT
- x 232
- x 8275
elma
- x 287
Off the top of my head Xantia 1.9tdcomes with 87H
Personally I think they are too thin skinned and puncture a lot so I use 87V.
In my opinion you will save more than £13 per tyre in puncture repairs if you go for over rated tyres.
The over rated tyres feel better under cornering load as well because they have thicker walls.
MikeT
- x 232
All I know is..... "The current UK tyre law requires that your vehicle is fitted with the correct type and size of tyres for your car. That means you must ensure the right tyres are fitted, and for safety making sure that they are inflated to the manufacturer's recommended pressure.citrojim wrote:Mike, I think C and U regs might have something to say about this.
The legal limit for minimum depth of the tread on your tyres is 1.6 millimetres, across the central of the tread going around the complete circumference of the tyre."
and....
"For MOT requirements in this country, it is not necessary to fit a tyre with a speed rating to match the original vehicle fitment or the maximum speed of the vehicle. Tyres must be suitable for the purpose for which the vehicle will be used."
EDIT: I just found the pertinent regulation...
"Tyre Loads and Speed Ratings covered by Regulation #25
All tyres must have a service description which describes its speed rating and load index.
It must be ensured that the tyres fitted to a vehicle are capable of operating to the loads and speeds that that vehicle will be subjecting the tyres to. The driver of a vehicle should check to see that the tyres are capable of carrying the loads and dealing with the speeds that the vehicle will be doing. If the tyres are found to be unsuitable, then the driver is responsible."
Just as I thought, tyre shops make more money selling us tyres we don't need.
- x 8275
MikeT wrote:and....
That is absolutely remarkable!
I'll get my coat and stand in a corner for the rest of the evening Mike
MikeT
- x 232
Stempy
But what about insurance? If you were unfortunate enough to have a prang could they use the fitting of lower rated tyres than standard to refuse a claim?
Lexia ponce
Lexia ponce
MikeT
- x 232
I would say no, not at all. (Unless you had said prang at a speed above the rating, I would say that is not grounds to refute a claim, but I'm no lawyer). But I wouldn't put it past them to try!Stempy wrote:But what about insurance? If you were unfortunate enough to have a prang could they use the fitting of lower rated tyres than standard to refuse a claim?
I had a motorcycle theft claim initially refused because I answered "NO" to the question;- "was the steering locked?". I should have sued them for slander as they considered me "negligent", even though there was no steering lock fitted to the bike!
As it happens, I recently read a motorcycle article warning that fitting any tyre that is not "standard" may invalidate the insurance under the category of "non-disclosed modifications".
elma
- x 287
THELABMAN
I had this quandry many many years ago when I was driving an old mark 1 Granada 3litre automatic.
At the time we had just got married and money was tight and I was having 2 remoulds fitted, in those days they didn't come in various speed ratings.
To keep my self safe I called into Motherwell police station and asked to talk to a traffic police officer, as they are based there, after exlplaining my predicament to him the advice I was given is that as long as you fit the recomended size of tyre the speed rating was immaterial as long as you didn't exceed the speed of the lowest rated tyre on the car.
I know laws etc have changed over the years and you have all this talk of insurance companies etc but as long as you stick to the speed rating of your tyre you should be fine.
I had a 1.9TD Sensation which should be fitted with 185/65/15 T rated tyres and yet everyone and there brother in-law tried to flog me H rated tyres, in the end I went for the H as I got them cheaper than I could find T rated tyres at the time.
Citroen C5 2.0 HDI SX Hatchback - 2002 (52)
Xantia Sensation 1.9TD (T) Mallard Green (Gone to the breakers)
