Xantia headlamp improvements
lolingram
RIP 2010
Unread post by lolingram »
As the find activity is US, I am asking for some help to improve the lighting on our 2 Xantias - a MK1, and a MK2.
Apart from the Phillips Vision Plus (and other) bulbs, I have checked the voltage at the bulbs with engine running, and with battery showing 14.2V, I am getting 12.62V at the bulbs... is it worth installing a couple of relays - 1 each for main and dipped functions, which for simplicity could be auto exited from the bulb terminals, with a direct fused feed straight from the battery?
Help appreciated.
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
x 8427
Hi Lol,
If only it were just the search function that was duff. I've been struggling to post anything since Saturday :evil:
A relay feed to the headlamps will make a great difference. It is quite a significant voltage drop you're seeing there. It's my next job to do on mu MK1. In the meantime I'm finding Osram Silverstars are doing a wonderful job; I recommend them highly. These bulbs are now available from GSF Mail order.
The relay wiring is very easy. Just take a fused supply directly from the battery to the bulbs via relays and use the old dip/main beam feeds to operate the relays. Use one relay for dip and another for main beam. A side benefit of using relays is you'll never have any throuble with the dipswitch contacts on the stalk.
lolingram
RIP 2010
I forgot to mention that the volts drop also clearly includes any earth return losses... any idea if it will mean running earths direct to the bulbs?
_________________
Previously...
x 8427
lolingram wrote:I forgot to mention that the volts drop also clearly includes any earth return losses... any idea if it will mean running earths direct to the bulbs
It will certainly be a good idea to do so Lol. I'd take new earths directly back to the earth plate adjacent to the battery.
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
hi Lol i did this recently - about 1 hour and £10
pm me if you want more info
i did a posting on it somewhere, just off home now, back on later
John
lolingram
RIP 2010
What relays did you use?
I see you run the only Jap bike that is worth the name....
John
_________________
99 -Xan TD LX
98 -VFR**************[VIN obfuscated, can be read by forum staff] 800 F1
Previously...
jgra1
(Donor 2021)
x 36
ooh :twisted: that will upset a few million bikers !
but thanks..
relays, I will check but just some I had lying about from some citroen.. probably 15 amp ones..
any wrecker will have them for peanuts
worth getting a bag full, as halfords charge about 10 each !
brought new cable, 15 or 20 amps, some female spades, thats about it....
will measure voltage later or tomorrow
John
