The central locking on my Dad's 1994 Xantia SX has just started acting up recently - sometimes when locking the doors it will unlock again half a second later - the same behavior you would normally get if the opposite front door was left open while trying to lock, except the other door is closed properly.
I've seen it happen in front of me for the first time today - and I re-closed both doors and it was still doing it, a dozen times, then a bit later it started working again - clearly an intermittent fault.
More worrying is that apparently it sometimes unlocks the doors some time after leaving the car "locked", thus leaving the car wide open to theft of contents...
I have to look at it in a couple of days, so can anybody give me some pointers ? I'm presuming that the fault can only be in the front doors (or the control system) as the rear doors don't have a sensor to tell if they're locked at all ? (They're just a passive slave)
When a front door is open the central locking will unlock after you try locking, so the switch/sensor that detects if the doors are open or not (in the lock mechanism, not the interior light switch) seems like the logical first place to look - except I don't know which door it might be.
Anyone had a similar problem and tracked it down ? In the meantime I've had to remove the central locking fuse to stop it from unlocking itself randomly...
Regards,
Simon
