Hi
Can anyone tell me if replacement of Xantia hand brake cables is a viable DIY job or is it best left to professionals? My nearside one is partially seized and not allowing the handbrake to release properly. I suspect the O/S one will be almost as bad.
Cheers
Dave
Xantia hand brake
- x 8264
Replacing handbrake cables looks like a right (censored) of a job
But, strangey enough, it's dead simple
The only thing to observe is the how the cables run through the guides, how they are routed back to the compensator and across the hubs and that they are "handed".
Be aware that 2.1TD, Activa and HDi N/S (or LH) handbrake cables are not the same as the other Xantia models and not supplied by GSF. I have an RH GSF one (all RH cables are identical) and a QH LH one. The quality of the QH cable is OK but not a patch on that supplied by GSF.
The BoL even gives a good write-up of how to do it. A wooden block to hold the exhaust heat shiled back to give access to the compensator aids things along nicely and the cable ends just pop out of the compensator with flick of a finger and go back in just as easily.
It looks hard but is in fact one of the easier jobs on a Xantia
Just remember to support the front of the car very adequately on ramps or stands before venturing under. Handbrake cables will be the least of your worries if the car collapses on you. Also, don't forget to chock the back wheels!
- x 1476
I broke a cable on one of my previous Xantias, and put of changing it as I thought it would be a git. Spent ages messing about fitting a ferrule on the end of the cable to make it work. Failed its MOT after the tester yanked the handbrake on hard and pulled the ferrule off (he was going to fail it anyway I think), so had to bite the bullet and fit a new one. I was really very very surprised when it took <1 hour - and that included pumping up the tyres on my project car, and jacking it off the axle stands! Once you figure out how to get the cable in / out of the compensator behind the exhaust shield it's child's play. Pleasantly surprised
mcgregor
- x 8264
jeremy
New cables are cheap - £10-£15 each I think. I've got Quinton Hazell ones on my BX as they have a thick plastic cover (like a hose pipe) which prevents the cable chafing in the wire type brackets on the hub.
Previous cables chafed at this point and the outer cable wore through entirely - wrecking the cable.
Binding a section of garden hose over a plain cable might achieve the same result.
The BX doesn't have the first cable from the lever - just the compensator - but even so I was warned by an expert that it was a horrible job - but having done it I'd say it was one of the easier ones I've done on the car - entirely straight forward and problem free with little or no additional dismantling - just make sure you get the route right and don't miss a bracket.
jeremy
mcgregor
- x 8264
Hi Dave,
QH part No MBC7425. This is for the LH 2.1TD and Activa but they'll be the same for the HDi
RH is MBC7195. Same for all Xantias
On-Line catalogue here:
http://www2.qha.com/catalogues/ZM11B.pdf
mcgregor
