on my '95 Xantia 19TD SX non AC.
No doubt this problem is as old as the hills on the forum
but the search option doesn't presently work!
Now before anyone tells me the problem is the ignition
switch, the HRW works perfectly which I understand is
a directly associated item to check with this issue!!?
Next obvious suggestion of course is the fan motor itself!!
I haven't had a chance to get upside down in the passenger
or driver's footwell yet, but what I don't get is it merrily
worked without ANY hicups or poor running right up until the
next day's trip to work where I'm now getting nothing at all.
Usually I've encountered signs of imminent disaster with
such items rather than instant inoperation! Just lucky?
Damned cold on the way to work...
Is this usually the symptom of a failed motor or would
there be ageing signs obvious beforehand?
I've checked the fuses too BTW.
What'd be my next port of call?
Andrew
