While preparing to remove the gearbox for a clutch change on my daughters 95 1.9TD I have found the back of the engine covered in oil - it appears to be from the turbo (not the feed and return lines) and there is also oil in the inlet pipework - the oil loss has not been noticable (on the floor or sump level) and the engine has been running perfectly.
Do I need to worry about this yet or is it a sign of imminent disaster?
Any views appreciated.
Richard
Xantia turbo oil leak
- x 1476
Duracell
jeremy
- x 8266
Turbos do get oily from small leaks on the inlet ducting. The inlet tract sucks fumes via the crankcase breather system and as a result, there is a lot of condensed oil running around the inlet tract. Because if its condensed nature, the oil is thin and will find its way out of the tiniest openings and after 12 years or so, there are plenty around the turbo and it's ducting; the oil fumes are very penetrating. If not massive, the leaks are nothing to worry about. All my older ones have had (and have) oily turbos for just this reason.
You might try checking all the joints around the inlet trunking but you'll likely not make much improvement
jgra1
- (Donor 2021)
- x 36
Hi, mine is the same.. the turbo is covered as is engine block, saying that, it's not a huge quantity (looks worse than it is)... first thing I will do is pay someone to jet wash the back of engine so I can see more clearly..Think mine will be HG.. changed rocker gasket last week..
if your doing clutch.. maybe take whole lump out for a look / repair? although a fair bit more work..
good luck
John
good luck
John
- x 8266
I wondered about the HG and looked at a head. It is very unlikely that the head gasket would be responsible for oil leaks at the rear as there are no oil galleries at the back of the head in contact with the head gasket. The main gallery is high up on the back of the head with drillings blanked with staked balls. It is conceivable, although unlikely, these could leak.
The oil galleries in contact with the gasket are on the sides of the head. These do sometimes weep a little as can be seen from oil around the vacuum pump but never does it seem serious.
jgra1
- (Donor 2021)
- x 36
- x 1476
When I took the head off my BX TD the back of the block and everything down there was covered in oil. The head on the other hand was bone dry - it can only have been coming from the head gasket
If you look up the back of the engine, you will probably see the same - block all oil, head dry. It may be that the oil leaks out at the front / side where the feed gallery is, then runs around the edge of the HG as the block is leaning back.
If you have a bad leak from the feed gallery, it pukes copious amounts of oil out behind the injection pump. That was the end of my first Xantia TD
lolingram
- RIP 2010
It is my experience that many (most?) XUDs will eventually leak from the HG oil gallery feed to the camshaft (just behing the inj pump). The 'O' ring in the gasket just rots out, and the leak can become extremely serious. I changed both my XUD head joint oil leaks: one (205D) at only 100k, the other at 250k miles.
In neither case did the valves need lapping in, or even adjusting, although I did the jobs on the 250k Xantia, as well as skim the head slightly.
This car still 'petes le feu' (goes like a bomb), and uses hardly any oil at all (mostly slight leaks).
If you have a bad leak from the feed gallery, it pukes copious amounts of oil out behind the injection pump. That was the end of my first Xantia TD Rolling Eyes
_________________
Must weld the decap...must weld the decap...must weld the decap...must weld the decap...must weld the decap
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
Previously...
