xantia battery terminal broken
the negitive terminal on my xantia battery has broken off and now wont screw tight, is there anything available which will hold the terminal in place. i cant imagine im the first to do this. the material used is like putty!
currently no citroens
1.4 2000 forte now gone too
xantia 1.8i 16v dimension 1996P now gone,
- CitroJim
- x 6204
- Contact:
Do you mean the terminal post on the battery or the bit with the wires attached that clamp around the battery terminal post?
If the former, a temporary fix is to carefully drill the post down the middle and insert a screw. It will not last though and a new battery is the only long-term answer. Don't try soldering it! too dagerous
The clamps are terrible and I guess this is what has failed. Replacement is the only answer and those normally supplied are not suitable as it is generally impossible to fit all the wires in them. A better bet are those rather blingy battery termainls sold for the barryboys and chavs to fit their megawatt stereo systems. These seem to have plenty of capacity for many high-current wires and are actually just the job.
Getting the old clamp off is a mission. Easy way is to use a pair of bolt croppers although a hacksaw will do the job. You may find it best to attach the thinner wires with crimp-on terminals to the new clamp but do use a proper crimping tool, not those cheapo jobs you so often see. If the holes in the new clamp are too big for the heavy wires, increase their diamater by wrapping some sheet copper around them to make a ferrule. I don't recommend soldering any of these wires as the act of soldering makes the wire brittle and they may break.
if the clamp has not actualy broken but just wont grip anymore, this is what happens when they are over tightend,
what i do is remove the pinch bolt, ease the lead apart, file the two matting surfaces then bung it back together,
but remebmer the gap is not ment to be fully pulled together, it should only be done up so it tight enough not over tight
regards malcolm
regards malcolm
- My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX - Contact:
Mine broke after it was refitted by a Citroen dealer mechanic. You can buy the new terminal lead assembly for about £15 I think from Citroen, but I just bought a pair of universal screw on terminal connectors, removed the screws and soldered the new connector on.
Lexia ponce
Lexia ponce
it is the actual part (of the clamp) where the bolt goes thought that has snapped off therefore it is impossible to tighten.
Is it possible to buy something like the item below and simply cut the wire of the old clamp, ensure a good connection and tighten the clamp onto the battery, as i think trying to hacksaw to old clamp is a lengthy job- if not too difficult (touching a large plank of wood as i type!)
http://tinyurl.com/2sy9el
jim
i should add it is the negative terminal and therefore only two wires, and not to thick. The +ve terminal on the other hand would be a different story, but that’s ok
All this started last week when Halfords exchanged the old battery under warranty (despite it being a couple of weeks outside the 3yr warranty-i think they made a mistake in reading the old receipt! just as well as the 'new' battery is £75- what a rip off if some poor sour is forced into buying one)
Being made of lead it's quite easy to melt off the old terminal with gentle use of a blow torch.
Lexia ponce
Lexia ponce
You can buy ready made leads with terminals on from many accessory shops - and so presumably factors - and probably Halfords. Just make sure its reasonably well made and that the copper bit isn't even smaller than the original - especially for a diesel engine.
You will probably need to measure your existing lead carefully or take it with you.
jeremy
