Anyone breaking a Mk2 Xantia Activa?
MikeO
Unread post by MikeO »
Does anyone know of a Xantia Activa Mk2 being broken?
Mike 8)
x 8272
Hi MIke,
No, unfortunately but one from a MK I will be just the job. There is no difference in the rams between marks.
before you condemn the ram completely, check exactly where it is leaking. The leakage return spigot has a tendency to fracture and although it's not easy, it can be repaired. Given the expense and rarity, these rams should only be written off if the ram itself is leaking. A fractured leakage return can loose a lot of LHM.
I once saw some puictures of a repaired ram and how to do the repair in French I think but cannot recall where.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
andmcit
x 30
Unread post by andmcit »
I don't know my Activas very well ...yet, but is the rear the same
as the front? There's a S2 Activa just turned up in my local scrappy
that's complete APART FROM the very item you want, the driveshafts,
the leather seats and the alloys. More directed towards Richard,
what do I really need to blag as some urgency before I repent at
my leisure later if I miss it!?
Are the strut tops and HP pump any different to the VSX? Which
bits are left that are rocking horse poo rare? The yard is very
reasonably priced as I'm a regular?
Andrew
john stenhouse
Unread post by john stenhouse »
My Xantia Activa went to Smiths of Bloxham, near Banbury. Don't know if its still there though.
Been gone a year now, but maybe worth a try.
DickieG
x 38
andmcit wrote:I don't know my Activas very well ...yet, but is the rear the same as the front?
No they are very different.
andmcit wrote:More directed towards Richard, what do I really need to blag as some urgency before I repent at my leisure later if I miss it!?
I'd grab the rear ram (be careful with the vulnerable return pipe).
andmcit wrote:Are the strut tops and HP pump any different to the VSX? Which bits are left that are rocking horse poo rare? Andrew
I believe the strut top's are different but the pump isn't, take a look at the front wishbones as they are different and cost £70+ each, also the roll corrector linkage and maybe the ecu's.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
