Help something is wrong weith my brakes, I just had front pads fitted and since then there seems to be a delay in operating the pedal and the brakes working'
When I brake car does slow but then brakes seem to suddenly grab, Is it the pads or just a coincidence, pedal feels ok.
Tony
Xantia Brakes
tomsheppard
xantaxi
tomsheppard
800 miles would seem to be enought to take the newness out. Without seeing your disks, I don't know if the wear is a problem. I'd be inclined to whip the pads out again and to see if they are making good contact with the disks.I would have expected the car to pull to one side though if that were the case. Further research: You may have drawn air in while pushing the calipers back for the new pads. Try bleeding.
The new pads may be a harder compound and have a different feel. Were they the same brand as last time?
The calipers may slide in their mountings and now be jammed having been disturbed. Somebody who knows your model better than I do will doubtless read this and advise.
The pistons in the caliper may not have been cleaned before they were pushed back and may be jammed in the caliper bore (which may itself be corroded slightly due to water in fluid).
David W
xantaxi
I just bled one of the front brakes and it solved it for a little while, it is now still pausing but not as bad, I am definitely on the right track with this, I will now bleed all of the brakes in turn.
Is it possible to use one of those self bleeding kits with a citroen?
As my wife is about as much help as a glass hammer.
Thanks again
Thanks again
Dave Burns
xantaxi
