My Hdi has developed a regular squeak somewhere in the cambelt area.
It seems to squeak twice for every rotation of the belt.
Its a bit annoying and loud enough to be heard faintly, at 60 mph with the radio off.
It doesn't seem to be the belt itsself.. I wondered if anyone else had possibly had this problem?
cheeers
Squeak somewhere around the cambelt area
c.morewood
- x 55
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
wrinklet1
jeremy
It could be a cambelt tensioner collapsing - which leads to belt failure. Same goes for the waterpump which is also driven from the belt.
It could also be one of the ancilliaries - pump, alternator etc or the multigroove belt itself but these sometimes quieten when running at speed.
Ideally you need to use a stethoscope to try and find the source of the noise. Placing a bar or length of wood on the subject and listening with your ear on the end of it may make a substitute.
Silicon sprays, WD 40 etc may help with diagnostics - (spray and it quietens - so that component is likely to be the culprit) - even for the multigroove belt itself (NOT CAMBELT)
jeremy
c.morewood
- x 55
thanks for the replies.. i just wondered if anyone had experienced this before?
The noise seems to be coming from the bottom end of the belt so i guess i'll have to wait for a day off..take off the wheel arch and see if i can get a better view from there.
Cheers,
Cheers,
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
CTR
c.morewood
- x 55
Couldn't get to the pulley unfortunately... I found out through trial and error that the pulley making the squeaking noise was the lowermost large one.
I sprayed WD40 onto a long rod and located the end of the rod just at the edge of the pulley next to the engine... after a good few seconds spraying the squeaking diminished so that I can hardly hear it.. I hope it lasts.. got to do 1400 mles in 3 days next month.. I'm just hoping its nothing too serious.
thanks for all the advice,
Cheers,
Cheers,
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
CTR
Yes, it is the one. And it may cause a Trouble!c.morewood wrote:Couldn't get to the pulley unfortunately... I found out through trial and error that the pulley making the squeaking noise was the lowermost large one.
Cheers,
If it is split - WD40 can make things even worse, - stop squeak but slip even more!
Check before you go! If You drive at night (light on) it will put extra strain
on the pulley - and it may just fall away - no alternator ant power steering in the best case.
c.morewood
- x 55
Well I joined the RAC and took the risk... did the 600 miles to Bournemouth, and the squeak stopped!! not a sound.. now I'm wondering if I should be worried about the silence!!
Thanks for all trhe advice,
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
c.morewood
- x 55
... and a few days later it was back.. so being totally fed up with the squeak and everyone staring whilst going round town. i decided to give it one more try before replacing the belt. I gave it a 2 minute jetwash whilst the car was running... that was 5 weeks ago and now i have .... silence... at last!!
I hope this thred helps someone.
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
