Can anyone help?
My brother in law has a Xantia 1.9 TD and just recently the fuel guage has started reading empty when there is plenty of fuel in it,the fuel "low" light even comes on,now i think its poss a knackered sender,has anyone had a similar problem?
Cheers
Xantia 1.9D fuel Guage
- x 8368
Hi Basher,
Welcome to the FCF
The frst port of call has to be to check the connections to the fuel gauge sender unit under the big round plastic bung under the O/S back seat.
Otherwise, the sender would appear to be duff, possibly just a punctured float.
It is easy to get to. Just carefully unscrew the big threaded ring on top of the tank that surrounds the sender unit and fuel lines. It is clearly visible and easily reached after removal of the aforesaid plastic bung.
Do you run the car on veg at all? This sometimes plays havoc with the sender unit...
Welcome to the FCF
XantiaMan
- x 18
Mine does, and the gauge is wildly inaccurate! Are you saying it has damaged the sender or the different viscosity affects the reading?citrojim wrote: Do you run the car on veg at all? This sometimes plays havoc with the sender unit...
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
2017 Fiesta ST
- x 8368
I don't know Gareth as I've not personally looked at a sender unit. I did wonder if the veg is conductive and did a quick test on some olive oil and found it a great insualtor but I could not try it on ordinary veg as we don't have a spot of the stuff in the house; we're strictly 100% olive oil hereXantiaMan583 wrote: Are you saying it has damaged the sender or the different viscosity affects the reading?
It may be attacking the float and making it sink or it may attack the resistive element in some way as it's usually fully exposed to the fuel. The last time I saw a gauge playing up on veg, the gauge would read low for a while after startup and then fall to nothing. That would suggest the float is Ok and it's electrical.
It is a shame none but very early Xantias had a water in fuel sensor
I don't think density or viscosity is the issue here although over the course of a journey, the veg in the tank will warm appreciably due to warm veg being returned from the pump after heating in both the filter and pump itself. Warming it may affect its conductivity possibly, especially if its not 100% moisture-free, the normal reason an oil becomes conductive.
basher998
bumperman
My Xantia(see profile below) has a pessimistic fuel gauge/warning light and I am running on 100% derv(so no possibility of system damage from veggie oil), until I get around to making my own bio fuel.
John
John
93 Peugeot 405 STDT ser 2 Estate manual Alhambra Red
89 Peugeot 505 GTi Estate manual Winchester Grey
87 Peugeot 505 GTi Estate manual Winchester Grey
96 Xantia td SX Estate RP6910 manual Quartz(silver)
DickieG
- Monaco's youngest playboy
- x 38
XantiaMan
- x 18
Any ideas how much Richard? Getting fed up with putting fuel in mine then watching it drop 10 minutes later!DickieG wrote:The sender unit on Xantia's is a weakness, the original one on my Activa would slowly cause the gauge to drop to zero. Fitting a new sender unit sorted it out.
2017 Fiesta ST
2017 Fiesta ST
basher998
