Hi everyone,
Are all spheres the same? Can I interchange them?
Thanks for any help
Are spheres interchangeable?
rory_perrett
pete the bus
I have 2 xantia estates, 1 for spares. The "good" car needs new spheres for the front, main accumulator, and anti-sink. The only decent spheres on the spare car are the front and rear ones. I will change the front ones over, but was wondering if i could use the rear ones on the spare to replace the main accumulator and anti-sink on the good car....
hope this makes sense ???
Regards
Regards
AndersDK
The accumulator sphere needs higher pressure than the rear wheel spheres initially are charged with.
The acc sphere is charged with 62bar.
The rear wheel spheres some 40bar.
- when they are new and have not lost any pressure.
Brand new boxed spheres are only some £22 from GSF. Its not worth the hassle replacing with unknown quality spheres.
Anders (DK) - '90 BX16Image
Mandrake
- x 694
Absolutely not - you can't use a suspension sphere (which has a damper valve in it) as an accumulator sphere - the damper valve will interfere with the pressure smoothing properties of the sphere, causing rapid pressure fluctuations as the pump operates.pete the bus wrote:I have 2 xantia estates, 1 for spares. The "good" car needs new spheres for the front, main accumulator, and anti-sink. The only decent spheres on the spare car are the front and rear ones. I will change the front ones over, but was wondering if i could use the rear ones on the spare to replace the main accumulator and anti-sink on the good car....
Regards
Likewise you can't fit any other kind of sphere in place of an anti-sink sphere because anti-sink spheres have a unique threaded pipe fitting in the neck of the sphere which other spheres don't have - you'll find it impossible to screw in.
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
