Accumulator Sphere
reservex
Accumulator Sphere
Unread post by reservex »
Further to a recent post re pressure regulator, what symptoms would a flat accumulator sphere present?
jeremy
Unread post by jeremy »
A flat accumulator will cause the system to cycle rapidly. (5-10 seconds)
To test the accumulator get the car to normal height and let it idle for a couple of minutes. Turn off the engine and sit in the boot. The car should sink a long way then after about 30 seconds rise to its original height powered by the accumulator.
To see what should happen do the same thing with the engine running - no difference - sphere OK - no response or feeble with the engine off - flat sphere.
New spheres are about £20 from GSF and their rivals. Full instructions for changing will be found on this site.
Remember to make sure the car is properly supported with room for you with the suspension down before working on it - the do KILL.
jeremy
reservex
Many thanks Jeremy
slim123
Unread post by slim123 »
Question.
Answer,
Tick Tick Tick Tick Tick Tick Tick Tick Tick Tick ..............
The faster the tick, the worse condition of the accumulator.
Regards,
Slim.
reservex
Thanks, but the unit is not ticking any differently than it has before just every now and again, not sure of the frequency as i have not timed it?
