Blown Turbo?
x 8272
Blown Turbo?
I'd be grateful if you'd give me your thoughts on this issue. It's not a Citroen but it is a 1.9TD in a Pug with an unfortunate taste for drinking its own oil :(
http://www.frenchcarforum.co.uk/forum/v ... hp?t=23157
Thanks. I'm particularly interested to know if in-situ replacement is possible :?
steelcityuk
Unread post by steelcityuk »
Does sound as though the turbos faulty. Either somethings got into the turbo or the blades are rubbing on the housing.
A secondhand one from the scrap yard and a recon kit would be my way of dealing with it.
Steve.
not applicable
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
hi Jim I have definately done a 405 turbo with no probs in situ..
support and take RH engine mounting off, will allow engine to be pulled forwards, helps no end..
it was some years ago, I suspect I removed inlet manifold then exhaust manifold / turbo ..
be slightly careful, some auto cars have turbos slighty nearer to header pipe as there are no gear control rods ... right pain if you dont know ;)
although only I could buy a turbo from an auto, they are not exactly common ;)
John
