c5 suspension problems
den169
My brothers c5 estate 2002 model is dropping right down when left for a couple of hours ,When the engine starts it goes back to the normal level,Oil is not low.Anyone had this or any ideas.
reblack68
- x 1055
den169
- x 1055
did the fault just all of a sudden start or did the front start doing it then the back (or vice versa) ?
Is there definitely no leaks ? are you checking the fluid level when the car is in the low position ? The anti sink valves are built into the BHI unit & controled electrically.
would you be able to park it up overnight & disconnect the battery as an experiment & see if it still sinks ?
den169
