Citroen Xantia 1.9TD Engine Management Light on
weety
Unread post by weety »
Hi Guys
been running my xant on veggy for quite a while without probs but its got a strange one now.
When the engine is put under load the management light comes on and the engine loses power.
I havent had a chance to check yet but i will look for air leaks and change the fuel filter tomorrow.
But does anyone know what the management system measures? is the car desperately trying to tell me it is suffering from fuel starvation....or could it be a more er interesting problem
or do i have an electrical problem :(
cheers
peter
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
XantiaMan
x 18
Re: Citroen Xantia 1.9TD Engine Management Light on
Unread post by XantiaMan »
weety wrote:Hi Guys
cheers
peter
You have an air lock possibly because of a blocked fuel filter or clogged fuel pick up in the tank. Mine did the same after running some crap biodiesel.
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
x 8275
That'll be right Gareth :) Spot on!
Nothing deadly serious 8)
I would however, in addition, check the fuel return line is clear back to the tank. It does sometimes block when running veg and the effects can be nasty, such as a fuel filter housing rupture by the fuel thermostat (the white bit that is visible near the filter housing base).
Fuel starvation and/or air will upset the timing servo in the pump that uses hydraulic pressure to function. The fuel is used as the hydraulic fluid.
The Engine Management (K) Light will come on if the timing the ECU tries to set on the pump for a given operating condition of the engine is not confirmed by the TDC sensor and the No.3 Injector Needle Lift Sensor. Basically, the ECU sets a timing value and measures the offset between the TDC sensor signal and the Lift Sensor to confirm the timing is correctly set. If there is air in the hydraulic supply to the servo, this will cause a timing error too large for the ECU to correct..
When the K Light is on, the pump defaults to a fail-safe fully retarded timing, hence the loss of power...
The sensors are OK, otherwise the K light would always be on.
weety
given the fuel system a good clean out changed the fuel filter and its fine again now :D
sailed through its mot again today (just an advise that a lower balljoint is starting to go) i just wonder how many years i can keep it going :D
