Mrs uncle buck has recently got a Xsara II 1.4 LX 2001...I'm more of a Diesel man myself & it’s a good few years since I last owned a Petrol car.
I noticed as soon as I drove it that it had a "Heater Matrix smell"... all I can describe the smell as is a hot smell...I have smelt this smell before but I don’t always think it means that the heater matrix is blown...I hope
My first thought are that the heater matrix is leaking & in my experience a blow matrix is normally as a result of a leaking head gasket, however the car doesn’t seem to be showing any symptoms of this...no Oil in the water or any mayonnaise deposits & the water seems to be staying at the normal level.
There does seem to be quite a bit of condensation coming from the exhaust pipe on tick over, even after a 15 mile journey, but as the car has a cat I believe this is not unusual?
Are the 1.4 engines prone to blowing head gaskets or heater matrix's ?
I also thought that as the car has air con you must get an amount of condensation from the evaporator & I would imagine this is situated beside the heater matrix...could the smell be this condensation being heated by the matrix?
Is there a drain off to take any condensation away...could this be blocked?
Any advice or tips would be appreciated.
Thank you.
Regards, UB
