AndersDK wrote:AFAIR there is some 3" differences between height settings.
That should give you some 6 inches max clearance - from the lowest setting.
If you're planning to test fording capabilities, please note that its the engine air intake that will stop your car, WHEN water gets in
- and that exercise will for sure cost you an engine
Speaking from experience, it can only cost you a new battery.
I hit what looked like just water on the road, but what I couldn't see was a dip under the surface.
Soon as I hit the water, I dipped the clutch so was probably doing just over 1500rpm when the engine stopped. Why they put the intake right down low I don't know.
Waited for the water to receed and for the AA to tow me home.
Removed all the air trunking, the intercooler and the injectors to drain and dry.
Then killed the battery turning the engine over getting the residual water out.
Think of four whales blowing side by side
The car ran fine afterwards, until a neighbour's little cherub torched it.
My concern would be residual water if you go that deep, sitting and corroding things, and messing with electrics as some Xantia's suffer from with just normal water ingress from rain!
