Camber on a V plate 1.9TD
KP
x 27
Unread post by KP »
Any idea what would cause my camber to be out on the drivers side by the amounts below at all anyone?
The guys that tracked my car said that it could be bushes but to take it to citroen to be checked out. Is it worth even trying to find out whats causing it to be out at all??
Image included here www.kingpleb.talktalk.net/Xantia/Scan_1.jpg
AndersDK
Unread post by AndersDK »
I take it you're talking front wheel camber ?
Any good indie could do a control arm bushing job. No need consulting Citroen.
Other points that influence camber on front :
1) Worn swivel joint.
2) Ride height setting at normal drive heigth. Rule of thumb : driveaxles to be precisely level at normal ride height. This takes any uncertainty of the actual correct height measurement as this will vary widely according to tyre fitment/condition
3) Upper suspension strut mount.
Anders (DK) - '90 BX16Image
KP
x 27
Unread post by KP »
Yeah anders its the front drivers side that seems to be the worst wheel :(
Ill have to look into the new bits of ruber when i have the spare cash to see what is causing it :)
lolingram
RIP 2010
Unread post by lolingram »
How does the car steer hands off?
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
KP
x 27
Unread post by KP »
It seems very straight to be honest with no real issues now the tracking has been done. ill give it another try in a few hours but im sure its fine and tyre wear was quite even on the front tyres so far :)
lolingram
RIP 2010
In that case if it ain't broke.....
It seems very straight to be honest with no real issues now the tracking has been done. ill give it another try in a few hours but im sure its fine and tyre wear was quite even on the front tyres so far Smile
Previously...
