xantia gearlever wobble
jonnydrumm1967
Unread post by jonnydrumm1967 »
Hi,can anyone help me on this?
When accelerating in 3rd or 4th my gear lever wobbles back and forth!
Power on-wobble,power off-no wobble. There are no other nasty noises,clonks or vibrations when this occours. Similarly,no thing untoward when taking up drive.
My thought was the lower engine mounting rubber on the offside
Car is a 97 model Xantia 1.9 TD.
Thanks.
2000 XANTIA HDi 110 SX Est
1992 205 GTI TD
1996 DISCOVERY TDI
2001 XANTIA HDi LX
1991 205 D Turbo
x 1238
Unread post by Peter.N. »
Could be a worn driveshaft or the engine running unevenly under load, but that's unusual.
jonnydrumm1967
I'll check the engine mountings,might just replace the lower off side one anyway.
There's no roughness to the powertrain,it's very smooth,even when the lever's moving back and forwards in its gait.
1992 205 GTI TD
1996 DISCOVERY TDI
2001 XANTIA HDi LX
1991 205 D Turbo
bigjl2
RE:wobble
Unread post by bigjl2 »
Had the same problem with my old 405 td, when I replaced the long driveshaft it went away, can only really be an engine mount if you get judder when taking up drive or shunt when changing gear.
Xantia 2.0SX estate (now sold)
Xantia 1.9 TD SX hatch 102K (all old MOT'S) and working A/C.(Sold to forum member, time to save for a C5)
2007 Berlingo Multispace 1.4i Forte, bought in November with genuine 27k miles, now on 39799 miles.
