My friends 2003 Berlingo Multispace with Air Con has developed what i feel may be either a Bitron unit or resistor failiure problem over christmas - in that no matter where the blower motor switch is the internal fans are going full pelt all the time.
Haynes BOL is a waste of time with regards the wiring, does anyone know where the resistor unit is kept?
Berlingo Fans Going Full Chat All The Time - WTF???
BernieLugg
BX
Xantia
Shed
Set of Spanners
Kettle
Xantia
Shed
Set of Spanners
Kettle
Clogzz
- x 40
Think that resistor speed regulation is used only in non air-conditioned cars.
Not sure of the model, but here’s for what’s called the Berlingo II VP.
Item 4 looks like the Xantia control module where the transistors go short and cause the blower to spin flat-out all the time:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=22398
01 6450 Z9 01 AIR CASING- RIGHT HAND DRIVE AND AIR CONDITIONING
02 6441 N4 01 HTR AIR PULLER- RIGHT HAND DRIVE AND AIR CONDITIONING UNTIL RPO No. 10555
6441 W0 01 - RIGHT HAND DRIVE AND AIR CONDITIONING SINCE RPO No. 10556
03 6447 Z4 01 POLLEN FILTER- RIGHT HAND DRIVE AND AIR CONDITIONING
E 146 001 01 FILTER ELEMENT- RIGHT HAND DRIVE AND AIR CONDITIONING
6447 SR 01 CHARCOAL FILTER- RIGHT HAND DRIVE AND AIR CONDITIONING
04 6441 78 01 CONTROL MODULE- RIGHT HAND DRIVE AND AIR CONDITIONING UNTIL RPO No. 10555
05 6441 Q3 01 GRILLE- AIR CONDITIONING
06 6441 G0 01 WATER PIPEDIAM INT 7- AIR CONDITIONING UNTIL RPO No. 10527
6441 W1 01 - AIR CONDITIONING AND RIGHT HAND DRIVE SINCE RPO No. 10528
07 6454 46 01 WATER PIPE- RIGHT HAND DRIVE AND AIR CONDITIONING
08 6450 NV 01 CONTROL RESISTR- RIGHT HAND DRIVE AND AIR CONDITIONING SINCE RPO No. 10556
09 6441 P6 01 EVACUATION PIPE- AIR CONDITIONING
10 6447 VV 01 FILTER PLUG- RIGHT HAND DRIVE AND AIR CONDITIONING SINCE RPO No. 10556
12 6450 JQ 01 BLOWER UNIT- WITH MULTIFUNCTION ROOF UNTIL RPO No. 10601
6450 VT 01 - WITH MULTIFUNCTION ROOF SINCE RPO No. 10602
13 6450 JR 01 CONTROL RESISTR- WITH MULTIFUNCTION ROOF
70 6912 C1 03 SCREW RLXDIAM 6X100-35
2002 C5 2.0i AL4 239,000 km 76372389
