Dears,
my 2.1TD/1998 seems to have this problem too (windshield gets foggy instead of "unfogging", even after ~30km drive). Here I would like to know few more details:
DickieG wrote:On the cars I've seen with a leaking matrix, white stains can be seen on the heater outlet in the passenger footwell and on the grey metal flap motor 'thingy' that protrudes down from the heater housing. Due to the shape of the inside of the heater housing escaping water will always fall onto the passenger side.
... seems that you're talking RHD cars, correct? Where would mine LHD drip? Passenger (on the right)?
DickieG wrote:... make sure you remove the metal collar for the aircon water drain in the engine bay before you pull the heater housing back, otherwise you will snap the plastic drain tube off allowing evaprated water to drop into the passenger footwell.
... where exactly is this collar accessible from/through? Any pictures or advices?
DickieG wrote:Also whilst the engine is hot, separate the matrix to heater connection hose otherwise you'll struggle to get that joint separated and snap the plastic hose connection, £75+ for a new one.
... heard about this trouble joint too, here on a local forum. Also - any advices where/when this joint needs to be disconnected?
Well, actually I plan to change this matrix anytime soon, since ventilation "fogs" my windshield, it's little bit smelly and in addition, the antifreeze is getting lost over the time. This all seems to be typical for leaking radiator, right?
Regarding the matrix size, local people advices that there are two sizes available, but not interchangeable: Valeo 234x156x42mm and Behr 234x150x43mm, where Valeo is probably more frequent choice for Xantia.
Thanks, Pavel
