Does anyone know what type/size battery the Xantia TD has fitted as standard at all as i cant see any markings that would indicate AH or CAC ratings on it and will probably give GSF a call in the morning to see how much one is as its a bit annoying this dodgey starting malarky everyday
Any help much welcomed and thank you to all the bigwigs again for getting this splendid place up and running again well worth the wait!
The Ampére Hours (Ah) is not that important. 66-88 Ah would be sufficient.
Whats more important is the crank power, i.e. the minimum Amperage delivered shortterm at full load from the battery. This should be at least 420 Amps.
You will notice that the price of the battery follows the crankpower - more than the Ah rating.
