I recently experienced a rather scary problem on my 212k miler Xantia 90hp HDi. Grandson noticed an oily tar dripping from under the car whilst parked. It turned out to be from the cooling sytem expansion tank overflow.... horror!
Upon checking the oil level it was found to be just on the end of the dipstick, BUT no sign of mayonaise. I feared this might be caused by a failing head gasket, but after due reflection I decided to check the oil/water intercooler sandwich, and this was the culprit!
A visit to the breakers (plus about 10 times flushing the cooling system) has resolved this anxious moment. BTW, a tip to aid the de-oiling of the cooling sys it to add a dishwasher tablet each time of flushing (not forgetting to backflush the rad), until all comes out clean as a whistle. Then add anti-freeze/inhibitor.
Best seasons greetings,
I have not heard of this problem on PSA diesels before (all TDs are thus equipped), so thought it worth a mention - have any others heard of this problem?
Oil in the water... HDi Xantia
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
Previously...
I've had this very problem on a 1989 V6 Xm which was a FCSH car from
new but sold out as spares or repair due to a possible failed head gasket...
and this was a good few years back when the car would have had a newer
cooler/exchanger!! The cooling pipes rotted out from the inside though
making life interesting!
The crap aluminium cooler/exchanger that lived under the oil filter was
changed to a heavy brick outhouse generation counterpart made of stainless
steel from a diesel Cx.
Andrew
Andrew
A few people have been trying to fix the problem on 2.5s on Club XM and an XU engine part has never been suggested as a swap, so I should think it is not compatible. I would have expected someone to have noticed the similarity with such a popular engine if you could use a scrap one from there.
Cheers,
Rowan.
Rowan.
Do something sooner rather than later... mine nearly emptied the sump into the cooling sys within 30 miles...Yep, I've got an identical car showing the same symptoms at the moment.
Is the cooler the same as the TD one? I possibly have another Xantia that's a
P plate TD showing similar signs too; I know how to find them!!
Previously...
Previously...
