Err no; they're no brighter over here either!!
alan s
RIP 2010
x 6
Unread post by alan s »
A soccer mum bites the dust..................or should that be sand................wet sand. :oops: :oops: #-o
http://www.news.com.au/story/0,23599,22 ... 48,00.html
This is what happens when you get a "make believe" work vehicle and try to do real work in it.
Alan S
RIP Sept 19th 2008.
She said "Put the cat out" She didn't mention it was on fire!!
bxbodger
Unread post by bxbodger »
To be honest that's driver rather than vehicle error- the Sportage has a pretty good off road reputation.I think the only thing that wouldn't bog in sand that soft would be a tracked vehicle!
alan s
RIP 2010
x 6
It's a combination of both; driver and vehicle.
4WDs on sand particularly DRY sand up the East coast are whole new animal and these toys just can't hack it. As I said in the title, the drivers ain't none too bright normally and the general impression this side of the pond is that if you can't learn to drive properly, then option 2 is to buy one of these impractical around town cars and work on the principle that everybody else will then get out of your way.
This usually works well until either another of similar talents driving one comes the other way, there's a tree or other obstacle that can't get out the way or they decide to try to emulate the ads on TV (as displayed here); then common sense clicks in, something that anybody buying a mythical truck to drive around town obviously lacks.
The area where she went down I know well; it was my old stomping ground as a teenager and the tracks she followed were made by a pro fisherman in an old Land Rover with balloon type sand tyres with around 10 psi in them that roll across the top of the sand. The toy by comparison has thin tyres running around 35/40 psi which cut nicely through the sand.
Doubtless, the toy has constant 4WD with no upper and lower range, so doesn't have the ability to crawl across the really soft areas, so when it begins to sink, they give it a bootful of power which drives the skinny wheels further into the sand and the fact she was down below the high tide mark tells me that is exactly what she did, but in a proper 4WD you can get out, but these wanky round towners is a whole new ball game.
As I sometimes get called in on retrieval of 4 WDs stranded on Fraser Island I see it all too often.
Don't know how they'll stand in regards to Insurance; could be a very expensive lesson in common sense and why not to buy soccer mums anything but a real car.
:twisted: :twisted:
Incidentally, the sand "that soft" is below the high tide mark and when we fly to the island, that is where they land the aeroplanes on. Leading to it is where the really soft stuff is as it's dry and not compacted and is easily driven on with vehicles with real 4WD transmissions and tyres. She obviously rolled through going downhill and started to bog just before the water line which was when the panic set in.
Alan S
RIP Sept 19th 2008.
alan s
RIP 2010
x 6
Here's a bit of "Local" entertainment over on Fraser Island.
This is what those who don't know how to drive 4WDs handle a simple situation and make it a difficult one:
If you want to roll end for end, then you do mental things like this:
(works well until you find a washout about a metre deep or drop into quicksand.)
This is how the ones who know what they're doing handle thick soft sand - not the best demo, but good enough to get through.
And if you drive a toy and haven't a clue, you end up like this or as the lady above did. :roll: :roll:
(Notice he didn't have the brains to have it in 4 wheel drive??)
Hope you enjoy.
Alan S
RIP Sept 19th 2008.
