Currently fuel gets sucked up from the tank into the pump first flowing thru the fuel filter housing. I do not have a priming device on this feed line from the tank
Should i install a feeding device to help the pump keep its fuel as when the engine is warm and shut down i get the feeling the fuel can flow back to the tank causing poor starting which i sometimes get when i next go to start her. this would prevent that by having a one way valve built into it.
Also i was thinking of having a small pump fitted into the tank or on the lin to help suck the fuel upto the pump to make it less strained on the colder mornings we get?
Next idea was to 'T' into the fuel feed line to the filter housing and then feed the return pipe into this. The return to tank line would then get the Injector Leak Off pipes connected to it so the fuel from them goes back to the tank and then using a plug on the fuel pump itself. This would help reduce strain on the pumps suction side on the colder mornings.
This is all in the aid of helping my SVO fuelled Xantia run a bit smoother on the cold mornings as ive already noticed a lumpy tickover at idle when she first starts up and she now takes 2 glow plug heats to get going so i guess they need doing as well so ill get some duratherm plugs when i can
Thanks for the help,
Will
