Xantia Speedo 'interface unit'
- x 1430
I found some info on another forum relating to a speedo interface unit curing flickering speedo probs on a 406 / Xantias. Can't find it in citroen-service though... Anybody know anything about it, or got a part numbr for it? Or even where it is on a Xantia (behind the glove box on a 406 apparently)?
elma
- x 287
TehAgent
- x 6
no hes on about the black box with a beige top, that the speedometer sensor sends the data too, i too have the same problem on my 406, just got the box out (from behind the glove compartment)
its got PPE-GF10 stamped on it, also another identity mark is on the beige plastic plate, its got the id IND.VE3 marked on it. looks acutely like someone with a xantia described
OK this link is for the wrong car, but its the same unit id imagine as what you have on your xantia.
http://www.peugeot406coupe.com/howto/1929SJ.pdf
Peugeot 208 active 1.6 EHDi
BMW 330i 2007
Mx5 Mk1 1990
BMW 330i 2007
Mx5 Mk1 1990
- x 1044
AndersDK
Nice description on how to replace the unit.
I seriously doubt though that this unit is any interface for the odometer readout. There are way too many wires on the units plug to fulfil this simple task.
It may be very true that the speedo sender unit is wired through this box for ease of wiring layout. But I cant imagine this box has anything to do with reading out the vehicle speed.
I'm much more inclined to think this is the factory fitted header unit for any on-board computer and/or speed-pilot. That would explain the wire bundle, as these functions calls for more complex wiring and electronic functions.
Anyways - on '95 on units on, the speedo is fully electronic with an electric pickup coil receiving the drive axles rpm. This unit is located as described above.
Anders (DK) - '90 BX16Image
DickieG
- Monaco's youngest playboy
- x 38
Richard,
IIRC is your Xantia is a S2? If so, is the flickering occurring throughout the speed range or just at the initial start/stop movement between 0-6 MPH? If it's the latter then that's a quirk of the S2 speedo, "They all do that"
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 1430
Yes, it's MK2, and yes it does the normal 'jump' on move off - but then it will sometimes randomly jump + or - 20 mph for a couple of seconds, or stick at say 30 mph then jump up to 60. The odo read out seems unaffected though, so I guess it's a fault with the speedo head. TBH it lies so much about the speed even when it's reading constant that I just ignore it, and it seems to have settled down now anyways - have done nearly 10k since I bought it at the end of August
h2ocooler
My 1998 2.1 TD started sticking at 50 or over reading by about 20mph, hitting the dash (when doing real over 50 would make it read right, now it just goes to 30 as soon as i start moving and stays there, given up now and use the speed indidicated on my sat nav now.
Will repalce the speedo at some point though.
Rob
Rob
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
- x 94
Mads
I have a problem with my Mk I Speedo, may be a touch more than "flickeringe" thoug
. On an other forum I was directed to a Swedish site, which recommended checking the soldering on the backside/inside of the speedo:
http://www.peli59.net/xantiafaq/hastighetsmatare.html
If you don't understand Swedish, the pictures should be self explanatory.
Haven't tried it myself yet, but others on the alternative forum have done it with good result.
Mads
C3 1.4HDi, 2003, 85000km
Xantia 2.0 16v Estate, 1997, 195000km
- x 1238
I have had a problem with intermittent readings on an XM, which was due to faulty connections where the red plug is connected to the instrument panel, I dont know if the Xantia is the same. Its due to poor crimping of the wires into the pins on the plug. I havn't repaired mine yet but someone who has says that you can do it using a thin pair of pointed nose pliers to close the sides of the contact up.
