Got another post runnig, but as this is another problem, i've started another topic.
My steering seems to make a hissing noise, almost like an air leak on a compressor line. It's not from the pump, but sounds like it's coming from the rack.
I've been away from xantia's for a while and can't recall this phenomenon. It still steers as it should and doesn't seem to be doing any harm, but just wondered what it is.
Also, when i press the brake pedal that also makes a loud hissing type noise...My BX doesn't do it and again i wondered what this could be. the brakes do seem to pulse with an inconsistent feel but I put this down to a shot accumulator sphere. Any ideas?
95 TD by the way.
Hissing from Xantia steering and Brakes
Hissings normal, pulsings air or acc sphere.
Do the brakes pulse at high revs? If so you definetly have air in the brakes and need to bleed them.
If they only pulse when the engine revs are low and the car ticks quite regularly at standstill then you should replace the acc sphere.
My moneys on air in the brakes as if you noticed the steering hissing you would probably have noticed the front of the car ticking.
A small hiss when turning the steering is quite normal - mine does it a bit especially on a left turn. If it does it even when not turning it might be a bit unusual...
Likewise a hiss or slurping noise from the brake pedal after pressing it hard and then releasing is quite normal.
Pulsing brakes is most likely air in the brake lines - give the brakes a good bleed, especially the back and see if it still does it.
Regards,
Simon
Regards,
Simon
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
