having a few problems with the front ride height of my TD xantia. The rear goes up and down perfectly, but the front will only go up and won't come back down. I jacked it up and had a good nose around the front height corrector and from what I can see the problem lies with the rod that pulls the height corrector back and forth(referring to the linkage rods that are connected to the height lever in the cabin). It looked to me as though the 8mm bolt that serves to clamp the linkage rod to the front height corrector is too long and is catching on the underside of the car when the lever is set to full low. So I chopped the end off the bolt, but am now having trouble setting the thing up.
I set the lever to normal ride height and then reclamped the linkage rod and tested to see if this made any difference. Now the car is stuck in high at the front and won't come down no matter what I do with the adjuster in the cabin.
Haynes doesn't divulge on how to set it up plus, I ran out of light to play about with the settings some more. I have a feeling I need to set the cabin adjuster to full high and then clamp the linkage rod.
Any opinions?
