Steering wheel remote control switch modification
MikeT
x 232
Unread post by MikeT »
The steering wheel switches are the rocker type that (presumably) conduct current only when held. Is it possible to change this to a standard on/off feed? For instance, push the "volume up" rocker and it switches on a circuit, push a second time and it switches off? Is there a simple or common device/relay I could get from maplins for instance?
x 8072
You would need either an RS flip-flop or a bistable latch for this Mike.
These are implemented in 74 series TTL or 4000 CMOS logic ICs or you could make up sets of latching relays to implement a bistable.
What is your idea Mike? I'm curious :wink:
MikeT
x 232
Initially, just an activation switch for arming/disarming the nitrous circuit.
Later I may get a progressive controller which has (four I think) front panel mounted push buttons which I presume won't need such a modification. I'm currently in liason with the manufacturer to see if they are indeed push & hold type controls and if I can tap into these in which case the steering wheel rocker switches will be ideal without modification.
The freed space below the radio will make a neat hidey hole for the controller and with the steering controls connector being behind the radio, would allow minimal and neatly hidden wiring.
x 8072
Ahh! I guessed as much Mike...
MikeT
x 232
Care to tell me more about the flip-flops and bistable latches, or do I ask google?
I nearly got driven over by a massive humvee-type truck the other day, I need more oomph Jim!
dan_the_v8man
Unread post by dan_the_v8man »
what about something a bit more simple, using the switch to latch a relay on and then use the other contacts to drop the relay out, may need a second relay to convert the normally open contacts to normally closed for the off function
Dec 94 Xantia LX 1.9 TD 116k - My first car :D
MikeT
x 232
I was hoping to get the on/off action from just one pole/throw of one rocker switch.
x 8072
Mike,
Wiki is your friend...
http://en.wikipedia.org/wiki/Multivibrator
No giggling at the title of the subject :lol: :P Look down the page for Bistable Multivibrators...
You need two transistors.
As Dan says, the same can be done with a small relay but much more elegant with transistors or even TTL or CMOS Logic ICs. You can make a Bistable using NAND gates, either using a 7400 (TTL) or a 4011 (CMOS)..
MikeT
x 232
Jim, I did read about RS flip flop and bistables last night and even went on to read about the IC's but I can't see any that flip from the one input only, they all appear to require two or am I missing something?
I may as well abandon that idea and just fit the kit activation switch in a xantia switch blank. I can then use the steering wheel switches to control the black box instead - I've been told it uses unlatched buttons that I can hack into at the pcb :lol: But in doing so will have to pass up on the extended warranty it has.
