beeping ZX radio
deian
beeping ZX radio
Unread post by deian »
Hi all,
I recently had a look at why the radio in my ZX needed screws holding it in place, so I took them out and had a fiddle. Then comes up another issue, basically since I had the car the radio has been anything but abysmal in sound quality. So I noticed some idiot has done a botch job on the wiring, it still sounds flat with a rewire.
Anyway... point is, to do this I had to disconnect the plug in the back therefore taking out the power, now then, the code was written on the bottom, so when I switched it on I typed the code in and pressed 5 to say yes (i think that is what I'm supposed to do). The radio then worked, but it kept beeping at me every few seconds, and then switched itself off. So I switched it back on, typed the code in, and it works, and does the same thing again. But the funny thing is I can type any code in and it works.
What's going on. I reckon the radio is a bit broken myself, especially with the manky sound coming from it.
Your input would be very much appreciated.
x 1431
To accept the code and stop it beeping you need to press the 4-way button (The one at the top left of the radio that does the search and functions) in the up direction. I don't think the ZX radios are as sophisticated as the Xantia ones, and just beep until the right code is entered and accepted.
deian
ok, i will try that, thanks
