A trivial question here,but nether the less important for me.
I've just been refilling my cooling system and following the manual's proceedure where you release one of the bleed screw caps.Well in my case i
had the bleed screw removed from the 't' junction pipework which sits just above the diesel pump and behind the the cam cover plate.
I was just going to replace the bleed screw cap(as water was escaping) when
I had a case of butter fingers and the dam cap fell somewhere behind the diesel pump,I presume??
Could I find the bleeder(sorry about the pun)
So i had a light bulb bubble appear above my head and thought,I know perhaps one of those bicycle tire valve caps would fit ! Sure enough it fits,
but I'm unsure whether it'll be a goog enough fit though.Would it last the hot and cold cycle of the cooling system?
Has anyone else had the same/similar problem and what was their answer to solve it.I'd be interested to know.
Thanks in advance to any of your answers.
Stevie
