There is water seeping right under the Thermo housing, is there are gasket or can I use a liquid gasket maker to solve that problem. The thermo it self has been changed but I still have a small water leak.
Thanks for any help.
Solly
thermostat housing ZX
JohnD
- x 72
sooty
jeremy
- x 3
I agree with Sooty - our 1.9 diesel has a plastic housing cover, no gasket and a sealing ring around the thermostat itself. When I changed the thermostat I was supplied with a thin gasket. The old gasket was thick and I was lucky to find an accessory shop which holds a stock of them. Refitting the old gasket was no use as it leaked gently.
Incidentally the current recommendation seems to be 80c and not 90 or so as recommended by Haynes. The heater seems fine.
The only good thing about the excercise is that I'm now very good at bleeding the thing. (I use a gallon plastic old antifreeze container and invert it into the filler cap with NO additional sealing, and simply squeeze to bleed the top pipe by the brake cylinder.)
Jeremy
Jeremy
ale2104p
