car wont start :(
jgra1
(Donor 2021)
x 36
car wont start :(
Unread post by jgra1 »
Chaps, i have a problem with a car I am trying to fix :(
its not French, but does begin with 'F' :evil: 1.8 Petrol, rail injection
It has sparks (2 brighter then than other two, a plug issue as i have tried swapping the leads),
fuel to/from the injection rail,
the fuel pump pressurises with ignition on..
there is power to the injectors, a constant 12v on ignition...
I am stuck really..
3 questions,
Is it possible that the fuel pump is pressurising, but not enough to get fuel through injectors? i.e. an inefficent pump?
how can I check the injectors are working?
could two weak sparks be the cause, seems to easy...
thanks
John
x 8331
Hi John,
The constant 12v to the injectors may be normal. It is on a Bosch system. The injectors are activated by earthing them.
The simplest method of seeing if the injectors are working is to listen to one through a stethoscope whilst the engine is cranking. You should hear them ticking. On a Pug or Cit the ticking is very pronounced at idle and it sounds like tappets needing adjustment.
Otherwise, use an oscilloscope across them or use an analogue voltmeter. The needle will measure the mean voltage across them and you may even see the needle flicking as they fire.
Even if you have sparks and injection, the engine may still refuse to start as the air:fuel ratio must be pretty nigh exact to allow a start. If it is way out it will not even fire.
The usual suspect on the F*** is the mass air sensor just downwind of the air-filter. It's a hot-wire one and a bit delicate.
Fuel pressure is an unlikely cause unless the regulator has gone completely and the fuel pressure is very low. You can do a rough test by letting the pump run, shut off and then carefully poke the schrader valve on the fuel rail (under a blue cap) whilst covering it with a rag and judging roughly the pressure released. You can even put a dial-type tyre gauge on it. Look for 2.5 bars or so.
The sparks may be a red herring. The coils are of the double-ended wasted spark type so one spark will be positive and the other negative. I'd expect them to look different because of this.
Hope that helps a little. SWMBO had a Fiesta as her first driving school car and then passed it on to our eldest son. I got to know F***s very well over the years as Dad also ran them until I converted him. SWMBO now rus a C3 as her tuition car :D
jgra1
(Donor 2021)
x 36
Jim many thanks great help!
I pulled an injector out and turned the engine over, and I thought I could feel it clicking in my hand..
Will try the analogue VM too. as another test.
I have swapped the regulator with a known working one to no avail.
I have removed the blue valve cap, and (i will check again) but i thought the drizzle of fuel from the valve wasnt that high - after pressurising.. saying that, when i removed either the fuel feed or return and put ignition on, there was plenty of fuel spraying around..
hmm...
glad SWMBO has moved to the correct side ;)
John
dnsey
x 19
Unread post by dnsey »
Watch you don't inject yourself with fuel :shock:
jgra1
(Donor 2021)
x 36
its a petrol injector, and it needs to be 'sat' in a pressuried bath of fuel to inject it ..
if you get me ;) ?
not like the high presssure diesel injectors, with they're own supply pipes
thanks tho :)
jgra1
(Donor 2021)
x 36
Well the problem was stupidly obvious, quite how the recovery guy missed it. .....
Cambelt fallen of the camshafts... not sure if it's snapped, still feels taught.. anyway, I dont suppose anyone knows if a Zetec engine will cope with this or not?
John
x 8331
jgra1 wrote:Well the problem was stupidly obvious, quite how the recovery guy missed it. .....
John
:shock: Very unlikely I would have thought John. They're hemi combuistion chambers, 4 valves per pot and inclined. They're going to bend big-time :cry:
Having said that, the Zetec is a nice motor to work on and you can have the old head off and a new one on with ease. There is nothing complex about them :wink:
The big hassle is timing them. You must use the kit to find the crank timing point and cam lock point. The cambelt sprockets are on tapers with no woodruff keys so you have to be very careful to torque up the two cam and crank bolts to exactly the right figures to prevent slippage.
reblack68
Unread post by reblack68 »
On cars without hydraulic tappets you can measure the valve clearances and that is a pretty good indicator of whether the valves are bent. I don't suppose that would work with hydraulic tappets though.
Richard
Care of a 1994 205 D.
x 94
Unread post by citronut »
youi could fit a new belt unless the old one has all its teeth, if so refit it after setting all the relavant timming points, then give it a compresion test, although you might find one of the tensioners/jocky wheels have colapsed
regards malcolm
AndersDK
Unread post by AndersDK »
First task is finding the cause for the cambelt slipping off :shock:
Idler(s)/tensioner/pump may have a worn & thus tilted wheel/sprocket.
Anders (DK) - '90 BX16Image
jgra1
(Donor 2021)
x 36
thanks all, will look this week..
certainly seems to have useful compression on 3 cylinders..
more to follow :)
John
jgra1
(Donor 2021)
x 36
16 valve ford, cambelt 'fell off' sprockets
ahh,,
Cambelt idler pulley is a steel center with a plastic outer.. the plastic is now seperated and also in a few parts.... methinks the belt and tensioner are/were way past service life
definate compression on 4, 3, 2 - 1 has nothing... asssuming 1-4 valves got it..
Told her I would do it for 2-250.. based on 2 saturday's work and parts.. seem reasonable? not sure what a garage would charge for a partial head rebuild?
thats working outside in nasty conditions...
Would you skim the head? no sign of HG troubles... I know its a fair effort to get it removed, and for £20 why not.. maybe it was damaged during the interference...
thanks as always
John
jeremy
x 3
Unread post by jeremy »
Professionals will have the head skimmed as a matter of course - how much will it cost to skim? How long will it take you to clean the old one? - that's the reason - it takes so long to clean if the gasket has stuck to it as many do and at current labour rates its not worth the trouble and you have peice of mind that its done and the head should seal properly.
So when you consider the cleaning time and the potential warranty claim - your decision is made.
Different if its your own car!
jeremy
jgra1
(Donor 2021)
x 36
thanks Jeremy makes perfect sense..
jgra1
(Donor 2021)
x 36
well the head rebuild all went back together nicely, in November :)
but.. a bad misfire is now occuring, esp on (heavy) throttle.. if you floor the throttle breifly, it almost cuts out.. car is almost undriveable
I have checked:
  • Coolant level fine, no HG symptoms
    Oil ok (Correct grade for Zetec engines)
    Compression, good on all four cyls
    Spark plugs all fire when out of cylinders, and all same colour.. failry lean
    Leads and HT pack swapped
    removed and cleaned TDC sensor
    jiggles wires to ECU
    general visual check of Vac pipes etc
have not checked, changed Lambda
Temp gauge has always read a bit low.. but if this caused a misfire I wouldn't expect it to happen when engine is cold..
can anyone help ?.
John
