Citrojim told me they can be difficult to fit, having to pretension against the springs to get the nuts on so I'm thinking maybe, use the longer bolts and after an initial period of bedding in, the shorter bolts replace the longer ones? But why the difference in metal?
Also, there are two washers (17) that are flat on one side and rounded on the other. Would they be fitted flat side up against the clamping brakcet or flat side down against the spring (D)?
