Having difficulty removing the rear spheres from my xantia.
They are v. rusty and lok like little cannonballs from the sea.
I can get a grip on them but the whole rear strut is trying to turn.
I've done rear spheres a few times before bu have never had this problem undoing them. Anny ideas? Should I take this one to a cit specialest to avoid problems?
Rear sphere change problem
- x 8067
Hi Elma,
You need to have the rear suspension on high to be able to undo the rear spheres. High is needed to expand the rams so that the suspension cylinder is held tight against the suspension mounts. You'll find it is quite loose if on low or depressurised. Trying to remove a sphere from a depressurised system risks damage to the hydraulic pipes.
You must be very careful doing this but set the suspension on high and just loosen the spheres off about 1/8th of a turn and then depressurise and fully remove the spheres. You'll find them very tight and you'll need a good removal tool.
TAKE CARE: These cars can kill so support securely on axle stands and ensure that when you are initially cracking off the spheres you are in no danger should the suspension suddenly depressurise and the car drop.
elma
- x 287
it is on high. Both wheels have been left on the ground, just clear of the ground and also on the ground but with the weight of the car on the jacks. None of the above works, the whole strut still wants to spin.
They are very tight and have broken both of my chain wrenches this afternoon.
I have a feeling I'm nogt gonna be able to do this.
- x 8067
Sorry Elma,
Should have said, you need the suspension on high and the wheels on the ground so that maxium compressive force is exerted on the ram/cylinder to make it as tight as possible. You may even need a paving slab in the boot
You need a seriously good sphere tool. Either copy Xac's or get a Peliades tool.
elma
- x 287
andmcit
- x 30
admiral51
- x 389
hi elma
probably wont help if you need the sphere off in next couple of days but i bought one of these
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... mot_widget
my back spheres were solid and like yours rusted (good description cannon balls
i gave the tool a slight amount of help with my trusty "persuading tool" and the vibration helped break the tension
he is also doing the acc sphere tool which looks even better allround use as it has a socket drive
colin
colin
Xaccers
- x 185
Take a look at http://www.frenchcarforum.co.uk/forum/v ... hp?t=21850
It's able to tackle some seriously tight spheres, especially the rears as you have the room to get a good long lever there.
Didn't manage citrojim's anti-sink or rear centre though, that required a pleides tool and a lump hammer I think!
DIY sphere tool
DIY sphere tool
elma
- x 287
Well food called so I didn't manage to get those spheres done yet.
I'll try again tomorrow with weight in the boot as jim suggested.
Failing that may I use your sphere wrench please Andrew? I'm not in cardiff at the minute but I'll be back within the next two weeks.
I hope I can get them off tomorrow though, you weren't meant to see the car again til it was finished.
- x 1238
I am afraid that a cold chisel and large hammer may be called for. I have had to use this method on several occaisions. The steady torque of the wrench will not always 'break' them, a short sharp shock is called for. Drive the cold chisel (it needs to be sharp) into the weld around the centre of the sphere, and drive it anti clockwise, a few sharp hits should free it.
andmcit
- x 30
elma
- x 287
I think I'm going to leave them until I see you now Andrew. They are definetly getting the better of me so far. I will consider the chisel as well Peter, but only if the sphere tool can't do it.
Can't believe the hassle they are causing. I've always told sceptical people that changing them is the same as a screw in light bulb and a child could do it.
Mandrake
- x 694
Well they are, in countries where the roads aren't salted......elma wrote:I think I'm going to leave them until I see you now Andrew. They are definetly getting the better of me so far. I will consider the chisel as well Peter, but only if the sphere tool can't do it.
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
KP
- x 27
- x 1238
