Wires with no home
Gregg1100
x 5
Wires with no home
Unread post by Gregg1100 »
Hi All,
Don't all faint. I have actually got the gearbox back in car - apart from the reason for this post, all back together.
Can anyone with a 16v Xant 2litre identify the 3 yellow wires hanging from just under the thermostat housing. ?? Obviously go to a fixing point somewhere around there---Are they earthng wires? I haven't put battery on yet as I didn't want the possibility of blowing something up.
http://img.photobucket.com/albums/v676/ ... 010524.jpg
http://img.photobucket.com/albums/v676/ ... 010523.jpg
Thanks,
Greg
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
andmcit
x 30
Unread post by andmcit »
Hi Greg.
Aren't these the earths that bolt onto the front right face of the engine
block just below the cylinder heads joint for the HG? One 10mm bolt?
Andrew
x 8088
Just looked at mine Gregg. The only difference is I have one thick wire bolted to the cylinder head in the position Andrew mentions.
Anything yellow and ending in a ring terminal will be an earth on a Citroen.
Gregg1100
x 5
Wires With No Home
Thanks for the replies--I will do that tomorrow--and get some new oil.
Regards,
Greg
