Where?
wigelywoo
Where?
Unread post by wigelywoo »
Where do we fill our Eolys tank and is the tank behind the heat sensor under the rear passenger seat?
I also get the sound of a pump running in this area for 3-4 mins after I stop the car, is this normal?
Also as the computer tells me "Diesel additive minimum level" do I have to go to Cit Dealer for computer reset?
Thanks...........
There are two secrets to success
1. never reveal all you know
wigelywoo
Someone out there must have the answers
x 1044
Unread post by wheeler »
wigelywoo
Thanks Wheeler
Do you know if the pump should run after engine is switched off?
And, Is there a filler cap for the Eolys tank?
x 1044
when you buy a refill it comes with a kit for filling the tank which consists of a pipe with a click fit connector, a pipe is uncoupled at the tank & it is filled via that.
the pump can run on depending on fuel level etc.
wigelywoo
The dealer told me that after filling the tank they then regenerate the system.
What do they mean by that?
