Hi,having removed an abs sensor from a breakers and then changing my duff one(NSF) I noticed the new one had a shorter spacer After a search in my shed I found that a rubber tap washer to be the correct thickness This is working,but can I regard it as a permanent fix
________
New mexico marijuana dispensaries
ABS sensor length
ABS sensor length
I'd made a similar discovery with differing age sensors' spacers too.
It's down to the size of the CV knuckle increasing over the original
fitment. I made the space up with several metal washers with the fix
bearing up well a few years down the line so you should be OK
with yours.
I'm just not totally sure whether the rubber washer will be strong
enough and may break up over time. Just a thought!!
Andrew
with yours.
Andrew
