Can anyone recommend a good detergent or other cleaning agent to remove the deposits that accumulate around the boot and filler cap area?
Neat washing up liquid doesn't work, nor does halfords car shampoo - even Gunk doesn't lift it off the bodywork.
Best cleaning agent for diesel/oil soot?
caveman_si
Petrol?
I remember being told that if you want to clean petrol deposits use diesel and if you want to clean diesel deposits of something use petrol. Never tried to use petrol myself as my jest wash gets its all off.
Also try wd40 its good for getting things clean. Give its a soak in the stuff and then try wiping off.
406 lx 1.9td estate
- x 8099
MikeT
- x 232
If petrol works, I presume it too will leave it's own residue - what's best for removing that after? WD40 didn't work for me. I don't have any of the other products suggested but I've got a splash of carb and brake cleaner in tins.
Jim, do you know what the active chemical is in Electolube? I can ask the chemist as it would be cheaper no doubt.
I've just come home to find cooking oil is pretty good at dissolving tarmac driveways
XantiaMan
- x 18
Traffic film remover. My 'petrol' cap area is mint
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
2017 Fiesta ST
MikeT
- x 232
XantiaMan
- x 18
Same stuff as bleach basically, you can get a similar effect using a cheap kitchen cleaner (Asda do one with added bleach for about 70p)MikeT wrote:Aha! Sounds good to me. Again, any idea what the active ingredient is?
Gareth
2017 Fiesta ST
2017 Fiesta ST
PicassoPigeon
davek-uk
Has anyone tried Magic Erasor http://www.jmldirect.com/Magic-Eraser-PM4712/ for car cleaning?
My poor white Xantia gets very dirty and one evening I had the bright idea of cleaning it. I clean my car every 6 months or so - whether it needs it or not! I was scrubbing and screeching the sponge and the muck still wouldn't budge. The other half said "Try this with just water" and handed me a piece of Magic Erasor. I used it with the hose to give a constant supply of clean water, and WOW! what a result. Women can be useful...
Simply rub the car all over and all the muck comes off - so simple. No scrubbing and scraping at tree and fly deposits. No using petrol to remove the tar (and veg oil) deposits. It really is magic! So much so it encouraged me to put a little wax on as well!!!
Pug Rifter long (20) - 41mpg - Gutsy for a 1.5!
Xantia 1.9 TD Temp.2 Break (97) - 208K@42mpg - Resting again.
Berlingo Multispace 1.6 16v (51) - 184K@36mpg - My shed! Still runs 15° retarded...
MikeT
- x 232
philhoward
TehAgent
- x 6
mbunting
MikeT
- x 232
Funny how these kitchen products don't do their intended job (at least not for me) yet will clean deposits it's not designed for. Cillit Bang works fantastically on getting the oil sooty deposits and other dirt off my car. It's great on the glass too - can see clearly at night now. Seems the log book is right - mine is white underneath!
