Can any one tell me what is the correct order for the assembly of parts used in the diesel fuel filter as fitted to my 1992 XM 2.1 turbo diesel using a Bosch mechanical pump. I recently replaced the filter and the new kit came with a small rubber washer that wasn't present on the old filter internals.
Another question I have is; how does the turbo diesel (with air to air intercooler) sense when extra fuelling is needed when turbo is boosting? ie under load. As a petrol engined car would have a MAP sensor, what does the Bosch mechanical diesel pump use?
The car shows a reluctance to accelerate over 3000rpm whilst under load. I have been told it may be due to a sticking waste gate. The engine is not burning oil and is returning 38mpg on fast runs.
Thanks for any advice
Doc
Bosch/Diesel fuel filter
JohnD
- x 72
Doc
