Xantia sunroof relay
elma
x 287
Unread post by elma »
Does anybody know where said relay can be had for reasonable money?
Citroen want forty something which I think is steep!
If anyone has a spare which works could you be persuaded to sell it?
Thanks.
andmcit
x 30
Unread post by andmcit »
Hi James.
Tell me which one you specifically need, and we can swap/barter parts
between us!! :wink: (pm sent). Is this actually the one on the sunroof
frame beside the actual motor?
Can't say I've ever bothered much with them as Xantia sunroofs are
usually reliable - unlike Xm ones...
Andrew
AndersDK
Unread post by AndersDK »
The relay is in essence a compact dual coil dual changeover contacts relay, to work as a polarity changer making the sunroof motor pulling either way on the control button.
Thats why its a "special" unit and hence expensive.
Same type of relay is used in many EW units, and the driver circuit for earlier CL control units.
Knowledge on car electrics and 2 standard changeover relays may fast and cheap make up a functional replacement as a bodge.
Andrew's hit on location seems just about right, as this is where I found it on my previous CX.
Anders (DK) - '90 BX16Image
